Hi! Sometimes the programm quits when sending message. And also the synchronizing process never stops. And I don ́t recieve messages. I have another account which works with the same IMAP. And this account works without any problems. Tried to reinstall the programm, delete and add again the account - nothing helped. The problem occured after licensing the product.
Are you using the same email provider for both accounts? If no, what provider are you using for the problem account. Do you get an error? Can you post a screenshot?
When sending message the programm quits and I get the following error
" name="" rel=“nofollow” target="" title="" type="" value="">http://emclient.com/ns/report">;
eM Client
7.2.34062.0
false
Microsoft Windows NT 10.0.17134.0
4.0.30319.42000
System.IndexOutOfRangeException
Índice fuera de los límites de la matriz.
MailClient.Imap.Base.dll
100663544
MailClient.Imap.Base, Version=7.2.34062.0, Culture=neutral, PublicKeyToken=null
MailClient.Imap.Base.ListParameter
FromStream
MailClient.Streams, Version=7.2.34062.0, Culture=neutral, PublicKeyToken=null
MailClient.Streams.UnbufferedTextReader
rdStream
mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
System.String&
input
System.Int32&
inputOffset
0
3ec
100663466
MailClient.Imap.Base.FetchNotification
.ctor
System.UInt32
messageNumber
System.String
line
reader
22
83
100663499
MailClient.Imap.Base.Notification
FromUntaggedResponse
System.String
line
reader
47a
74b
100663432
MailClient.Imap.Base.Connection
ParseUntagged
System.String
line
14
2d
100663435
ParseReply
System.String
line
f7
233
100663430
ReceiveWorker
11
4f
mscorlib.dll
100678625
System.Threading.ThreadHelper
ThreadStart_Context
System.Object
state
14
9c
mscorlib.dll
100678355
System.Threading.ExecutionContext
RunInternal
executionContext
System.Threading.ContextCallback
callback
System.Object
state
System.Boolean
preserveSyncCtx
79
e4
mscorlib.dll
100678354
Run
executionContext
callback
System.Object
state
System.Boolean
preserveSyncCtx
0
15
mscorlib.dll
100678353
Run
executionContext
callback
System.Object
state
2b
40
mscorlib.dll
100678627
ThreadStart
8
43
* 4032 FETCH + Ready for literal data
* OK [CAPABILITY IMAP4rev1 CHILDREN ENABLE ID IDLE LIST-EXTENDED LIST-STATUS LITERAL- MOVE NAMESPACE QUOTA SASL-IR SORT SPECIAL-USE THREAD=ORDEREDSUBJECT UIDPLUS UNSELECT WITHIN AUTH=LOGIN AUTH=PLAIN] IMAP server ready H mieue042 14.0 IMAP-1M7bAr-1gWL9g0NW1-006dQ1
MailClient.exe
C:\Program Files (x86)\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
7.2.34062.0
eM Client
eM Client
7.2.34062.0
False
False
False
False
False
Independiente del idioma
ntdll.dll
C:\Windows\SYSTEM32\ntdll.dll
ntdll.dll
ntdll.dll.mui
10.0.17134.407 (WinBuild.160101.0800)
DLL del nivel de Windows NT
Sistema operativo Microsoft® Windows®
10.0.17134.407
False
False
False
False
False
Español (España, internacional)
MSCOREE.DLL
C:\Windows\SYSTEM32\MSCOREE.DLL
mscoree.dll
mscoree.dll
10.0.17134.1 (WinBuild.160101.0800)
Microsoft .NET Runtime Execution Engine
Microsoft® Windows® Operating System
10.0.17134.1
False
False
False
False
False
Inglés (Estados Unidos)
KERNEL32.dll
C:\Windows\System32\KERNEL32.dll
kernel32
kernel32
10.0.17134.376 (WinBuild.160101.0800)
Archivo DLL de cliente API BASE de Windows NT
10.0.17134.376
False
False
False
False
False
KERNELBASE.dll
C:\Windows\System32\KERNELBASE.dll
Kernelbase.dll
Kernelbase.dll.mui
10.0.17134.376
False
False
False
False
False
ADVAPI32.dll
C:\Windows\System32\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
API base de Windows 32 avanzado
10.0.17134.407
False
False
False
False
False
msvcrt.dll
C:\Windows\System32\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.17134.1 (WinBuild.160101.0800)
Windows NT CRT DLL
7.0.17134.1
False
False
False
False
False
sechost.dll
C:\Windows\System32\sechost.dll
sechost.dll
sechost.dll.mui
Host for SCM/SDDL/LSA Lookup APIs
10.0.17134.1
False
False
False
False
False
RPCRT4.dll
C:\Windows\System32\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
Tiempo de ejecución de llamada a procedimiento remoto
10.0.17134.407
False
False
False
False
False
SspiCli.dll
C:\Windows\System32\SspiCli.dll
security.dll
security.dll
Security Support Provider Interface
10.0.17134.376
False
False
False
False
False
CRYPTBASE.dll
C:\Windows\System32\CRYPTBASE.dll
cryptbase.dll
cryptbase.dll
Base cryptographic API DLL
10.0.17134.1
False
False
False
False
False
bcryptPrimitives.dll
C:\Windows\System32\bcryptPrimitives.dll
bcryptprimitives.dll
10.0.17134.345 (WinBuild.160101.0800)
Windows Cryptographic Primitives Library
10.0.17134.345
False
False
False
False
False
mscoreei.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
mscoreei.dll
mscoreei.dll
4.7.3056.0 built by: NET472REL1
Microsoft® .NET Framework
4.7.3056.0
&nb
And yes, the same provider for both accounts. And very strange that the problem started to occure after the licensing. During the trial period there where no problems at all.
Also the programm quits but the message is send.
The problem solved. Kaspersky antivirus was the cause
