Hi
I am running Windows 11 (25H2, build 26200.9457) with three monitors configured as follows:
- Monitor 1 – left-hand monitor
- Monitor 2 – centre monitor, and the Windows set primary display
- Monitor 3 – right-hand monitor
I am running eMClient (v10.4.5674 with a personal license). The main eMClient window is normally positioned on Monitor 1 (the left-hand monitor).
I have noticed an issue when moving an email from my Inbox to another folder.
I normally use Ctrl+Shift+V , which opens the “Select Folder” dialog. However, instead of opening on the same monitor as the eM Client window (Monitor 1), the dialog always opens on Monitor 2, the Windows primary display .
This is particularly noticeable because eMClient itself is running on Monitor 1, so I have to move my attention to the centre monitor (2) to interact with the dialog and then return to Monitor 1.
Ideally, the “Select Folder” dialog should open on the same monitor as the eMClient window that spawned it, rather than defaulting to the Windows primary monitor.
I appreciate this is a relatively minor issue, but it is something I encounter frequently and is quite annoying in a three-monitor setup. Hopefully a emClient developer monitors these forums and could log it as a development/bug issue (A positive programming opportunity)
