Mr. Anand P
Ask to Save sent messages.  A much needed feature IMHO, it would be most helpful if the system can be configured (via parameters) to ask the user whether a sent message should be saved or not.  I end up sending tons of emails which I don’t need to save and I have no choice now but to go to the sent box and delete them one by one.  Going through each sent mail to see if it is worth retaining is a chore.  This is much easier if done at the time of sending itself as memory is fresh.  This can be achieved on outlook using VBA but why not have this baked into the app itself?
If it is emails you regularly send to certain addresses or domains that you don’t want to keep, you could create a rule to delete them after sending.
