Mouse click sensitivity
Does eMC exercise any control over mouse click speed sensitivity? I ask because I’m finding that when I click in the scroll bar elevator (especially when doing Move to Folder) that I’m sometimes getting the effect of two clicks (i.e. two scrolls up or down of the visible set of folder names) when only clicking once. This is not a problem I generally encounter when using other Windows applications’ scroll bars.
Thanks…Neil
Hello Neil, eM Client does not include any special setting for double click speed and uses the standard double click speed for your system. The application is built on Microsoft’s .NET framework and most of these features are .NET controls of system elements.
Hope this helps,
Thanks Paul. It helps in that it means I have to better discipline my index finger…
