Shortly after downloading a picture for a new inbox email, everything except the heading vanishes. After sending a reply, the original email changes to the sent email. The delete button should be on the left, above the email list. I was MUCH happier with ver. 6 Can I get it back?
Hello Howard,
We’re sorry you aren’t happy with version 7. Two of the things that you’re not happy with can however be easily changed in the settings.
Can you send us an example of such a message in .eml (please right-click it and select ‘Save As…’) to [email protected] with a link to this thread so we can examine it more closely?
eM Client 7 has a new feature called Conversations which groups together message that share a subject. If you go to Menu -> View -> Conversations -> and choose Disable Conversations, the settings should be to your liking.
If you right click the Toolbar (e.g. the Delete button), please select Customize and move/add the buttons as you’d like.
Maurice
