In Local Folders, I have message headers, but the message content is blank.
In some folders I can see message headers but contents are missing
In other folders I can see messages and contents
I think there has been an auto update?
Im on 8.0.2951
Hello maharg,
Searching for updates obviously does not work in version 8 (yet).
You can download the current installation file from https://www.emclient.com/release-history.
Create a backup of the data in eM Client before updating. Also keep an earlier backup where the display of messages was still ok! (V8 seems to have some bugs, if you read the forum like this…)
miércoles 09 septiembre 2020 :: 1917hrs (UTC +01:00)
The latest version is: 8.0.3385 (83a873c)
If you simply want the latest EMC v8 rather than an update this link will always deliver:
https://www.emclient.com/dist/latest/setup.msi
Sometimes it is better to start with a fresh install when you have problems, if you go this route:
- DO NOT FORGET TO BACKUP EVERYTHING BEFORE YOU START
Russ
