I’ve been using the software for a few weeks now without problem. Turned on my computer today and it doesn’t work. It automatically runs database check which results in the error 'SQL logic error or missing database table mail_index.Mailtems. Then I get a pop-up with the following error…
The following error has occurred:System.Data.SQLite.SQLiteException (0x80004005): SQL logic error or missing database
no such table: contact_index.ContactItems
I’ve run a virus scan, malware scan and CCleaner - all fine.
I’ve run the database repair tool recommended here which just runs the database check with the same error I mentioned first.
I haven’t made any changes on my computer and no one else uses it.
Totally at a loss, can anyone help? Thanks!
