Migration between Servers
Hi all,
I’m about to change my IMAP Hosting Server to another company and wondering what’s the best way to transfer my 3GB Mailbox between the two.
Using emClient or someother method.
My internet connection is not great 100Mb/s down and 20Mb/s Up.
TIA
After setting up the new hosting & IMAP mailbox, then add in the new IMAP account in eM Client via either the automatic account wizard or manual setup depending on your server type.
Then drag / move all your existing acct messages and any custom message folders directly to your new IMAP account.
Once you are then certain all your messages and any custom message folders are all in your new IMAP account, remove your old account.
Note: After you drag / move your messages to your new IMAP account to see when it’s completed, click “Show Operations” via the dropdown arrow on the right of Refresh.
Lastly before doing anything, make a manual backup of eM Client via “Menu / Backup” incase you need to restore for any reason. You can also see when that’s completed via Show Operations.
