Is there a way to migrate or synchronize rules such as blacklisted domains across devices or do I have to keep recreating them on each device?
Hi Joel.
You can’t synchronize but you can copy them. That is done through Menu > File > Export > Export settings to .xml file. Then select only Rules. On the other computer it will be Menu > File > Import.
Some Rules will not work if they refer to folders that don’t exist on the target computer, but the Blacklist certainly will work.
Thanks. Well my db just got corrupted so yay me. Maybe I’ll try another email client.
