Messages with subjects in the Russian language imported with strange symbols.
Hello, while importing personal folder from Outlook 2016 all messages with subjects in the Russian language imported with strange symbols.
Possible to do something?
Dimitry, do you have a Pro License? If so, I suggest you open a ticket with this problem. Olivia Rust just recently solved a problem with character encoding, and I am sure that they will have some useful comments on this one also.
Hello.
Yes, I have Pro License and ticket was opened month ago.
I’m hope problem will solved, until now I have edit all(about 300) messages and remove strange symbols.
For now I do not need any fix, I do not need to import any messages.
But this can helps to other one.
Great! If you do get a solution from Support, posting it here would help. :slight_smile:
