Messages don't start
Messages stay in the send box.
That’s a frequent probleme for me and many people I help …
Thinking to leave Em Client no answer to the question …
Quite dommage!
Hello Noussibeau,
I am sorry but I don’t clearly understand your issue. Do you mean that your emails get stuck in the outbox while sending?
Thank you for further explanation.
Russel
Yes exactly … some messages for reasons I ignore stay stucked in the mails box…
Perhaps a too great number of recipients or a too important volume of added documents … but most probably a temporary error of the SMTP servor.
It seems that if a message is refused for any reason Em don’t try to send it again … and I didn’t find a way to resend it easily.
Thanks for help
Hello Noussibeau,
Could you please check if your SMTP settings in Menu > Tools > Accounts are set correctly according to your service provider? EM Client doesn’t have any limitation on the message size or number of recipients so the only limitation might be set by your provider and it probably wouldn’t cause this issue.
Russel
Hello Russel
I checked everything I could about my SMTP serveur (Gmail) and my friend (SFR) it’s alright …
But problem stay!!
It seems that once a message has not been send for some reason (temporary lack of smtp for instance, Em serveur don’t try to send it again and I did not find any way to manualy resend tne Mail …
Regards
Eric
