Message window does not allow text to be copied
Is there a way to copy text in the message window as I do most of my reading there?
Can you screenshot an example where you are trying to copy from ?
Blank out anything personal
In the message window text cannot be copied from the message…yours may be to the right side or bottom location or possibly disabled.
Ok looks like your referring to the “message preview window” text. You can normally copy text from the preview message window.
If this is happening with every message, I would suggest to uninstall eM Client and if you have Windows “don’t delete the database” when asked on the uninstall wizard and then reinstall and see if that fixes it.
If it’s only happening with specific emails, then they might be eg: protected in some way from copying text like eg: protected pdf files etc.
Thanks for the follow up…I’ll report back once I’ve done some more checking.
Thanks cyberzork…took a restart of my computer [which I should do more often] to fix the issue.
