Message pane
i’m using vertical view and i want the message pane to have messages on 2 rows (not one row with many columns). But i can have this view only if i keep the message pane very small.  i want to keep it a bit larger but if i do then i see only one row for the messages
ok i found it
Hello Marco,
Thanks for letting us know you have found the settings that works for you (presumably by selecting the compact layout option in Menu -> Tools -> Settings -> Mail -> Read - Message List).
Maurice
