As mensagens antigas da pasta “caixa de entrada” desapareceram. Estou aflito. Não sei oq ue fazer para as trazer de volta se é que é possivel. Alguém ajuda sff? Obg
what exactly did you do before it happened? Do you use IMAP or POP3 protocol?
Hello
Thank you for your reply.
I did nothing. I use IMAP protocol.
However, I noticed that the messeges constant in this PC were all transfered to my portable PC where I also have the same email account.
I don’t understand why the messages that were already on de the PC were transfered to the portable PC.
I deleted the account on the portable PC and hope this action ( transfer messages) no longer happens.
Best regards
Alcino Matos
