mails from my inbox always disappearing, please help....
NULL
Do you have some ‘rule’ defined, which automatically moves incoming e-mails to another folder?
Hi, what email service provider and what email protocol do you use?
Jan
i have no rules defined. i am using cox, protocol pop3 (?)
you can check your protocol in tools - accounts - your account, depends on what tabs you will have there.
Anyway check that pop3 tab (if you really have POP3) and tell me your settings at bottom of that tab (I mean those where you can check if you want to keep or delete emails.)
Jan
