MailExceptions.OperationExceptions
Seit OwnCloud 8.2 funktioniert die Kalendersynchronisierung nicht mehr. Bei jedem Start erhalte ich die Meldung:
OwnCloud Kalender [CalDAV] MailExceptions.OperationException: Die Synchronisierung von OwnCloud Kalender/ ist fehlgeschlagen mit folgendem Fehler: OwnCloud Kalender (Not Found)
Eine Idee woran das liegt?
could you please go to Tools > Settings > Advanced and turn on CalDAV logging?
Restart the application then and when this error pops up again, go to the Advanced settings again to Send logs.
Change the recipient to me ([email protected]) and put link to this forum topic in the body of the email.
Best regards,
I checked the logs and the error is on the server side.
eM Client is trying to access the calendar inbox for event invites using the schedule-inbox-URL, and the server gives it an address, which, when trying to access the node, doesn’t exist.
Please contact OwnCloud support.
Best regards,
