Em Client will not start. I get a text box that states there is a corrupted file. When troubleshooting, it says mailclient incompatible.
I reinstalled the program a few days ago and it would open and I could sent and receive documents . Three days later, the problem reappeared.
Any Ideas on what I can do to fix this?
I’m using windows 10.
Hello Patrick,
Could you please send me a screenshot of the error together with the Logs to my email: [email protected]. For the logs, go to Menu > Tools > Operations, mark all rows with CtrlA and copy-paste it into a .txt file. Send me this file in an attachment please.
Thank you.
Russel
Hello Russel, I can’t open the program therefore I can’t send the information you asked for.
Here is what the pop op message says:
System.IO.IOException: The process cannot access the file because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.__Error.WinIOError()
at System.IO.File.InternalMove(String sourceFileName, String destFileName, Boolean checkHost)
at DbRepair.CorruptionChecker.CheckCorruption(RepairOptions repairOptions, CancellationToken token)
at DbRepair.CheckingProcess.Check(CancellationToken token)
Data:
databaseFile: accounts.dat
Trouble shooter message:
Program Compatibility Troubleshooter
Publisher details
Issues foundIncompatible Program
MailClient is incompatible.
Detected
Fix program MailClient
Completed
Issues found
Detection details
6
Incompatible Program Detected
Fix program MailClient Completed
Provides steps to fix the incompatible program.
Compatibility Mode
Compabitiliy modes applied: Windows XP (Service Pack 3) Run as administrator User verification: Fix didn’t work
Detection details
Collection information Computer Name: DELL-PC Windows Version: 10.0
Architecture: x86
Time: Tuesday, October 17, 2017 11:50:56 AM
Publisher details
Program Compatibility Troubleshooter Find and fix problems with running older programs on this version of Windows. Package Version: 2.0
Publisher: Microsoft Windows
Publisher:
Hello Patrick,
It seems that another program is using eM Client’s database. Please make sure that is not happening - usually it is an antivirus program or any other security program. Try disabling these before you start eM Client next time to see if it helps.
Russel
