MailClient.exe /dblocation and Theme Editor
So it appears that when I launch the emclient with the /dblocation paramater “MailClient.exe /dblocation” the themeeditor fails to apply any theme changes that are made. I can launch it but it doesnt let me apply it. I get an error “Error when connecting to a running client. Please make sure that the mail client is running.”
Should this be expected to work when the dblocation is something other than the default?
Win10 Pro x64 / eM Client v8.1.876
Thanks,
~SOL
The recommended method is to launch the application with just MailClient.exe, and set the database location using eM Client’s settings in Menu > Settings > Storage.
I guess as it is not expected to run eM Client with the dblocation parameter, the results might be unexpected.
If you have a Pro License you could open a support ticket with eM Client.
That seems to have fixed it. The path in the GUI for the Storage Location was still the default. When I changed it to what I wanted to be it, the Theme Editor seems to work. I forgot about that part of the profile data.
Thanks for that!
~SOL
