Long start up time when recovering.
Some of my installed programs, such as Windpows XP Pro, send down unsolicited updates to my software without asking. When that happens my system is forced to reboot. If eM client is running I have to do a restart. The current eM client software has to do a database corruption check as part of the restart. That process takes an inordinate amount of time. Are there ant plans to speed up that process? Than you.
please try to upgrade to latest stable version scheduled to be released soon.
you can downloaded it here: http://www.emclient.com/dist/v5.0.183…
if problem will persist please tell us what antivirus software do you use because this tends to happen with Avast.
anyway another solution could be setting system updates to be manual so you will have time to close eM Client properly.
best regards
Jan
