Hi all and thanks for this great application. I wish you more power.
I have a little problem while i add the shortcut to the startup folder. eMclient fails to load at startup. I’m on windows 7 SP1. Anybody facing this problem? or is it just me? I thought it will be fixed with the new updates… i updated just now and still its the same.
Any help… much appreciated.
regards
Does it display some error message or it just hangs in background?
I’m running Windows 7 Home Edition 32bit SP1 also, and I’ve no problems with starting from the autostart.
the error msg follows: “eMclient has stopped working… windows will check for a solution online” then it just disappears. then eMclient is not running in the background… i need to run it manually.
I also have admin privilege.
Try install it from http://www.emclient.com/dist/v3.5.123… .
If it will persist can you please send an email (with reference to this forum topic) to [email protected] ? We will give you further instructions.
And adding to that we will appreciate if you send us files from directories (or only the newest one) starting with “AppCrash_mailclient.exe_” from
c:\Users[YourUserName]\AppData\Local\Microsoft\Windows\WER\ReportArchive\ to [email protected] with reference to this topic.
Thank you dear Gabriel,
The link you asked me to install from, doesn’t exists
“404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.”
I have emailed you the file you wanted me to send you.
Thanks again
more power.
I am sorry, we are changing are update system meanwhile. The link http://www.emclient.com/dist/v3.5.122… should work and we will analyze the files you sent.
Thank you again, I uninstalled and re installed from the above link. Still the same. I will wait for you to analyze the file.
Reagrds.
Gabriel, i got the reply to my email. It’s fixed now. Thank you so much for the entire team. Good luck and I wish you guys success!
