lizenz immer wieder deaktiviert! benötige ständig den lizenzschlüssel???
Hallo,
beim EM Client wire immer wieder die  lizenz deaktiviert! benötige ständig den Aktivierungsschlüssel??? woran kann das liegen???
Grüße
Hi Dirk,
eM Client has a one license per device policy.
You need another license for your second device, or you will be prompted to activate each time you switch devices.
okay i tray one more time
 mogens
Hi!
I use two computers with two users for everyone.
Do I need to order one licence for each computer?
Every computer has a second user.
Thank you!
Hello Torsten,
you need a license for each device.
If you have separate user profiles, each should contain it’s own database, so the license can be the same - so 2 licenses should be enough.
