I have several contacts from the same company. Outlook allows me to link them. Can I do that with eM Client?
You cannot link them, but you can create a distribution list which will contain all the contacts from the same company.
Thanks George. Is there a way to use groups? How?
Groups should be propagated into eM Client as a separate distribution lists. Then you can add them into “To” field and send an email to multiple recipients in a few clicks.
