I just bought Emclient and downloaded version 10.0.2622 but when I try to activate it, there is no “License” option
This is a beta version, therefore no license required
Did you buy a lifetime license or version 9? If you bought a lifetime, no problem. When the public v10 is released, your license code will be fine.
If you purchased a v9 license, hmm. I’d contact the sales department and see if they will work with you.
Thank you for your response.
I bought a lifetime license, I downloaded the v9 and entered my license key.
