License and installations
Hi, I have had a new motherboard put into the computer and now EM Client is saying there is no license found there are too many installations. I have 2 licences
If this is for a Pro License, you can go to the License Manager, and deactivate the one you used on the old motherboard. Then in Menu > Help > License, you can activate it as normal.
If this is for a Free License, you can register another one under a different email address.
Hi thanks, for this, do you know how to reset the user name and password on License Manger as I have no idea what mine are?
Go to http://www.emclient.com/reset-password and enter the email address you used to register.
