I have Version 7 of emclient. I had the same version on a previous laptop where I was somehow able to remove the calendar, tasks and widget functions from the left sidebar. I don’t use them and only want mail and contacts. I now have it installed on a new laptop, Windows 7 and can’t figure out how to remove these functions from the left sidebar. Please advise.
Thank you.
Click the 3 … at the bottom of the folder sidebar
Click “Navigation Options”
Use the pop up to add/remove
There are no dots anywhere on the sidebar. Please can you provide screenshot of where they should be?
My apologies as I seem to have thought you were running eM Client v8 and that is what I sent you a screen shot of.
I am not sure but I think you can right-click Calendar or one of the others and then uncheck it… wish I could remember but a combination of age and not having run v7 for months now seems to be my enemy
There is no option. I have tried literally everything. However on my old laptop I have the same version and I somehow removed them so there is a way.
Please can anyone using Version 7 tell me how to resolve this.
Thank you very much.
This should help…
@tazerqueen In v7 right-click on any of the large left hand categories (‘Mail’, ‘Calendar’, ‘Tasks’, ‘Contacts’).
You should see something like this - I’ve right-clicked on ‘Mail’:
There are ticks next to all four categories - I have all four displayed.
If I now left-click on any of the four ticked categories, the tick toggles off and that category disappears. Here I have right-clicked on ‘Tasks’, left clicked on ‘Tasks’ in the pop-up to remove the tick, hidden ‘Tasks’ and then right-clicked on ‘Calendar’ to show the current status. ‘Tasks’ is unticked and no longer appears:
Because all four always show in the right-click menu you can easily toggle them on/off.
There is also a ‘Widgets’ option you can turn on!
