I seem to have the ‘leap year bug’ as well. I can start emClient but as soon as I click on Calendar in the left hand pane emClient crashes with the following dump (excerpt) in the error window. Incidentally, changing the system date did not ‘fix’ this issue for me and this suddenly started at 12.20 a.m. this morning (29th Feb) - the first time I used emClient after midnight. When I click on Calendar I get a small calendar appearing in the left hand pane with 29th Feb highlighted (see screenshot). emClient clearly cannot cope with a date it doesn’t think exists. Database corruption checks etc on restart are fine.
eM Client (6.0.24316.0)
Windows: Microsoft Windows NT 6.2.9200.0, Framework: 4.0.30319.42000
System.ArgumentOutOfRangeException: Year, Month, and Day parameters describe an un-representable DateTime.
at System.DateTime.DateToTicks(Int32 year, Int32 month, Int32 day)
at MailClient.UI.Controls.Calendar.MonthCalendarView.RefreshScrollbarProperties()
at MailClient.UI.Controls.Calendar.MonthCalendarView.ViewActivate(Boolean refreshvisibledays)
at MailClient.UI.Controls.Calendar.CalendarView.controlCalendar_ViewTypeChanged(Boolean refreshvisibledays)
at MailClient.UI.Controls.controlCalendar.DelegateViewTypeChanged.Invoke(Boolean refreshvisibledays)
at MailClient.UI.Controls.controlCalendar.set_ActualViewType(ViewType value)
at MailClient.UI.Forms.formMain.ActivateEventView()
at MailClient.UI.Forms.formMain.ResetFilter()
at MailClient.UI.Forms.formMain.ActivateToolStripConfiguration(String configuration)
at MailClient.UI.Forms.formMain.ActivateEventLayout()
at MailClient.UI.Forms.formMain.RefreshEventLayout()
at MailClient.UI.Forms.formMain.ActivateEventFolders(Boolean expandBox, Boolean ensureFolderSelected)
at MailClient.UI.Forms.formMain.leftSpine1_BoxActivated(Object sender, EventArgs e)
at MailClient.UI.Controls.ControlSidebar.ControlSidebar.OnBoxActivated(ControlSidebarBox box, EventArgs e)
at MailClient.UI.Controls.ControlSidebar.ControlSidebar.box_Activated(Object sender, EventArgs e)
at MailClient.UI.Controls.ControlSidebar.ControlSidebarBox.Activate()
at MailClient.UI.Controls.ControlSidebar.ControlSidebarBox.Maximize()
at MailClient.UI.Controls.ControlSidebar.ControlSidebarBox.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at MailClient.Program.b__4()
at MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action`1 handler)
