Downloaded eM Client update last night, this morning the calendar reminder box will not close without pop-up application error box appearing to say error has occurred ‘System.Argument Null Exception: Value cannot be null.’ etc etc. Closing this box shuts down eM Client. On reopening pop-up window ‘client database check’ always appears. Thanks. KB.
Do you have a back-up of a previous database before the upgrade? If yes, let know which version of eM you were running.
this issue is solved in build 3.5.13654 which you can download at http://www.emclient.com/dist/v3.5.136…
We are sorry for any inconvenience this may caused.
Thank you, the problem is now resolved
