How can I update a localization dll with the emclient-localizator.zip?
I don’t like to make a complete new language file just update a existing one with some corrections.
The localizator.zip do not contain the base files as described.
I just extract it out from the delivered dlls to xml, changed some words, created a new dll.
But this new dll contains the updated words only…
If it’s just corrections then write them to us to support@emclient.com. It is possible to manually adjust the language files with our localization tool (http://www.emclient.com/localization)), but we don’t recommend it because it would break with every update.
There are some bad strings I would like to correct as they appear, not spesially seeking them. I’m translator and I could translate file in whole, but I have little time for thousands of lines :-)).
When I will finish, I can send result to developers… progressivly…
