Key activate wrong
 Por favor, em varias vezes hum msg RESPOSTAr Silverlight  “chave ativar Errado”. QUALQUÉR Organismo pode me Ajudar?
Hello Romulo, I’m unfortunately not quite sure if I understand, are you having issues with activation? what kind of issues? Can you please make a screenshot of the issue and submit it to us here on the forum?
Muito obrigado por me ajudar. Eu tentei mais de 100 vezes para inserir a chave abaixo, minúsculo, maiúsculo, e só responde chave errada. Agradeço se você tiver qualquer suggestions.Name: Romulus
Empresa:
Tipo: Free
Usuários: 1
Emitido: 2015/05/28
expira: 2016/05/27
chave de ativação: 46f37a64-ae9b-42bd-BB62-da14e4973d4c
Hello Romulo, please do not post your activation key on a public forum or anywhere else on the internet, this is a public page and anyone could start using your activation key like this, disabling you from using it yourself. Please make sure to edit out the activation key from your post.
There’s currently no activation made using your license key, so you should be able to activate. I’m unfortunately still not quite sure what kind of an error you’re referring to. If you’re still experiencing this, please make a screenshot of the issue.
Before you do so however, please make sure that no other application is blocking the connection to the server and that eM Client is able to connect to Port 80 or it’s licensing server at http://licensing.emclient.com/ , if you’re using any security software on your computer, try to temporarily disable it and check if the issue persist.
