I am trying to clean up and unsubscribe to junk emails as I get waaaay to many. In the process some mail that is not junk gets sent to Junk folder, so I right click on the non-junk ones and and choose move to inbox and remove from blacklist email and remove from blackmail domain and yet they still keep going to my junk folder???
DON’T unsubscribe with spam messages. Often they are just phishing emails, and when you unsubscribe, the spammer immediately knows the address is in use, and you can be added to a list and sold onto other spammers. Best is to just delete them.
For messages that end up in Junk that shouldn’t be there, that really depends on what is moving the messages to Junk to begin with. Normally, it is your server, so you will need to login to their webmail interface, select the message in spam, and mark it as not spam. Thereafter the server should always leave messages from that sender in the Inbox.
But it can also be caused by eM Client moving the messages if you have previously blacklisted the sender or their domain. If that is the case, go to the Junk folder and right-click on the message choosing Move to Inbox > Move to Inbox and remove blacklisted … This option will have no effect if it is the server moving the messages. You can also go to Menu > Rules and edit the Blacklist Rule if you have one. See if the sender’s address or domain is in the list and remove it.
The Spam filter Rule will move messages to Junk if the server has marked them as spam but not already moved them. If this Rule is the cause, the you can either train the server not to mark them as spam, or disable this Rule.
Thank you for the response. Good idea to catch them at the server level, did not think of that, seems to be working, will keep doing it. Unfortunately I was hit with over a thousand emails at once during the end of last summer, someone charged something to me (An IPhone) and it seems that is something they do so you dont see any warning emails about a charge, so I have alot that I try to get rid of and have to try unsubscribe also.
