Jump to next unread message
Hello all,
is there a way to have such kind of behaviour, which would make it possible to jump to next unread message by push of key shortcut. Similar function is in Thunderbird, where by pressin “n” when reading mails I jump to next unread message received regardless in what folder/account it is located. It kind of saves lot of scrolling when multiple accounts are used. I did not found such a kay.
Thank You,
Daniel
Hello, this is unfortunately not an existing feature of the application, you can however read your unread email from the unread smart folder which should only be populated by your unread messages.
Paul,
thank You for clarification.
Daniel
