Is there a way to join contacts?
I mean I have a contact as a company. An a lot of contacts with direct numbers and email addresses from that company. They are all now single contacts.
Thanks
Thanks
Hello, it’s only possible to merge contacts into one, by drag and dropping one contact over another, this however should only be applied in case you have a duplicated contact, I’m not quite sure if it could apply to your scenario.
You can also create distribution lists and select your contacts to be used and linked with the distribution list, select your contacts and select “Create distribution list…”.
