Hi I am having issues while trying to print the email. Firstly, It does print pictures or other jpg file attached in the email. Secondly it automatically closed while trying to print the email which is very serious issue. This happened after I upgraded to Beta 11. Kindly fix these issues urgently or get me back the previous version if this cannot be fixed.
Hi @2189034 - the BETA is a testing version, so it can unfortunately happen that an unexpected issue occurs.
The best way to report issues with the BETA is to contact [email protected] - that way, our devs are informed about issues right away, and they can create a fix before the final release.
We do have some internal fixes in version 11.0.625 connected to some print issues, so it is very likely this issue will be resolved in the next update.
If you don’t want to wait for the update and don’t mind getting a version that has not gone through all internal tests yet, please do reach out and request it at [email protected].
Dear Olivia,
I have already sent an email to the given address as per your instruction and just now i faced the same problem while trying to print email. All the opened emails that need to be worked on, has closed automatically which is really frustrating. Please address this issue on TOP URGENT AND PRIORITY
