Hi i am using MailCow, with EM Client on mobile. I sent a few attachments but the end user is not getting them. Is there anything in my settings i should check. FYI when i used outlook mobile i did not have this issue at all. So i take this is client issue.
Are the attachments showing in your eM Client mobile app sent box ?
Also if you send an email with an attachment “to an alternate email address of your own”, can you see the attachment in your webmail Inbox ?
Yes and yes? I am wondering if it’s now working? When I sent a PDF in the past to my doctor office or some organization they where not getting it. But when I used outlook it did. I also sent a email to Gmail just now to test and it is working. I am not sure if i fixed the issue or if the issue is still here. I did play around with encryption. That could be the issue? But yet I believe encryption was off when I sent the PDF files in the past. So I am not sure if this is resolved or not.
In the past it showed sent from my mailbox, but the end user never received it. I also noticed my own em client was able to see the attachment.
Yes and yes?
If you can send an email to your Gmail address and see the attachment ok in your eM Client sent folder and also see the attachment in your Gmail webmail page sent folder, “then the problem is at the receiving mail client end” and not eM Client with either some sort of restriction in the receiving mail client or the receiving mail server.
Yes encryption might affect the recipient opening the attachment “if they are not decrypting your email properly with their client end”. So suggest to “not use any encryption for your next message” to that recipient and see if it works.
If it still won’t show the attachment at the receiving end without encryption , then “ask the receiver if their have an alternative email address you can send to for a test” to see if it’s a restriction with their current email client / or their mail server.
