I want to change always download pictures from sender back to where you get to select if you want the pictures downloaded?
Yes, if you go to Menu > Tools > Settings > Mail > Privacy. First you want to make sure that the option to only download from senders in the whitelist is selected. Then you can remove that sender from the whitelist. Click on Show whitelist, then click the X next to the sender’s address.
Thanks Gary, that was the answer I needed. Your response was so fast (and with a picture) I first thought it was an auto reply. Attention management, you have my permission to give this guy a raise!
