Is there a possibility to save attachments and remove them at the same time from e-mails?
NULL
Hi Reto, not completely sure what you have in mind, unfortunately eM Client options do not allow you to automatically save and remove attachments from messages, attachments can be automatically downloaded with the received messages but will only be available for offline use using eM client, if you’d like to save the attachments into a selected folder, that is unfortunately not possible using the eM Client’s options.
Paul
