Calendar integration & syncing
Hi Jonathan, unfortunately it is not possible to enable automatic synchronization between two separate calendars, you have to add the calendar to each of these calendars if you want the event to sync with both servers.
Paul
You can do it with a third party app called gSyncit. I do it that way and it works fine.
Alan
Hi Alan, glad you’ve found a solution, please make sure to let us know if you come across any other issues or questions about the application, we’ll be happy to help.
Paul
