Hi there,
I have just downloaded eM client for the trial period of 30days in place of Outlook (New) which I hated and I would like to know can I also install eM client on my iPad Air IOS 18.1.1 and how do I go about this as I would like to be able to sync my PC & iPad Air due to the fact that I quite often work from my iPad Air more than I do my computer.
I am only requiring it for Personal use as I am now retired.
Thanking you in anticipation.
Kind regards,
Patricia Turner
eM Client currently has an iOS mobile iPad app via the Apple App Store.
Once you install that, then go to eM Client Desktop on Pc or Mac “Menu / Tools / QR Export” and follow the wizard where at the end will appear with a QR Code for you to scan with your iPad app.
Then open the eM Client iPad app and “Skip the setup” and choose the “Scan Barcode” option and put your iPad in front of your computer to scan the eM Client code and then follow the eM Client iPad app wizard to automatically setup.
Or open the iPad app and skip the setup wizard and then go to “Menu / Settings / Import/Export” and click “Import via QR Code”. Then scan the barcode on the eM Client desktop program and follow the wizard to automatically setup.
Now if you then have an IMAP, Exchange, Office 365 or iCloud account then you will be able to send and receive email on both your computer and iPad exactly the same with the same mail folders etc.
Lastly the eM Client iPad app “currently only has Mail”, but it will also have later a “Calendar, Contacts and Tasks” etc sections.
