I have em10 installed and am trying to exame em11 before purchase. Must I uninstall em10 before instaling em11?
No you don’t normally need to uninstall V10 and can upgrade directly to try V11 to test it.
Just backup your current version first via “Menu / Backup” incase you need to restore for any reason. Also close eM Client before updating.
Then click the link below to download the Beta and you will see links at the bottom to upgrade.
Note: if you are having problems upgrading from V10 using the (MSI installer) and have Windows and have an IMAP, Exchange, Office 365 or iCloud account and you have no messages in Local folders, “”then after backing up eM Client”, and closing eM Client, uninstall V10 and “delete the database” when asked on the uninstall wizard and the d/l the V11 Beta (MSIX installer) to setup new. But normally the MSI u/g installer works fine.
