I have also set up an “outlook.de” address in the newly installed program. The inbox works, but I cannot send any emails. What settings do I need to make and where?
Thank you for your support.
Make sure to enable the AirSync service for it in Menu>Accounts.
The reason why we made this change from SMTP is explained on this blog:
Thank you very much for your support. Since I had already installed a newer version, I had no choice but to uninstall and reinstall the program. Now all the settings are correct and sending messages works.
Thank you very much.
