Each time I open my client, my inbox opens half ways down ie. I have to scroll up to see my latest Email.
Is there any way to have the inbox open showing the latest mails visible and, possibly limit the size of the inbox to 25 mails
Hi, what version of eM Client are you currently using?
You have the option to setup the default sorting if new messages are on bottom or on top, but the default position should always be on top.
There’s also no option to limit the size of your inbox.
Problem solved .Thank you
Glad I could help, let us know if you come across any other issues or questions, we’ll be happy to help.
Is it possible to sort the Inbox mail as per read or unread
thanks ahead
GN
Hi, yes you can sort your received messages based on the read/unread flag. If you’re using the messages on the right layout in eM client, please click on the “Sort by” option above the list of received emails and select Icon to switch between read/unread.
If you’re using the messages on bottom option, please click on the icon column to start sorting based on the selected column (icon).
Hope this helps,
Paul
