Impossible to make a connection
Dear Sir,
Thanks to your quick reply I found out the name of my provider which is Gmail. The name of my new email account will be:[email protected].
I am encounterings problems when making contact to this account. I receive always the same message which is: An attempt makinng contact to [email protected] failed. This could be caused by temporary inavailibity of the server or incorrect settings. Check your settings.
Can you please take a llook to my settings.
My settings are: host : pop3.gmail.com.
Which one should I take: use identity credentials or use these credentials.???
Login name and password are filled in correctly
Smtp Host: smtp.gmail.com
Use SSL/TS if available is marked
Authentication:
Same problem as pop which one should be filled in. Use identity credentials or use these credentials.???
Login name and password are filled in correctly.
Could you please check these settings so that I can use this email aacount.
I am most grateful and thank you in advance.
Kind regards
Jacques Molenaar
P.S. My operatingsystem is Windows 7
host for POP3 isn’t “pop3.gmail.com” but “pop.gmail.com” .
POP3
Host: pop.gmail.com
Port: 995
SMTP
Port: 25
Milos Kovalcik
