I’ve exported Access 2010 Contacts table to a .csv.Importing it into emclient is strait forward except for one thing.
When assigning the phone number the what choice should I use?
Some phone numbers are home some are mobile and others are work
What will the column heard be if I simple select ‘Phone’ and no particular type?.
If you have three separate columns in you CSV then there is no problem. Just assign each one; mobile, work, home. If you only have one, just select phone (as you have suggested) and you get a non categorized phone field.
I see now.
I only Have 1 column for the phone.
But, I can’t find a available column to display the phone number in 'Phone List.'Unles I go and edit each and the phone number field assignment.
No. After I import, and if I use only ‘Phone’ for the phone field and view ‘Phone List’ There isn’t a field for it such as 'Home Phone, ‘Mobile Phone’.
Yes, I could do that.
I found it easier simply to select ‘Home Phone’ during import.
Wouldn’t be bad if one would be able to edit the column header text.
But, all-in-all I find em client a very good product.
