Imported contacts not showing
I have just started using eM Client with gmail (IMAP), and everything works very well, apart from a strange issue with contacts.  If I try to import new ones from an Outlook pst file, it looks as though the import is fine, as the correct number of new contacts is shown in the progress box, but the new folders that I have created don’t appear,and the contacts (including distribution lists) cannot be seen anywhere.  However, they do pop up when I search for contacts in the ‘To’ field of a new email.  So, where are they hiding?
Make sure that on the contacts tab on the folder pane, the local folders/contacts is checked.
Dear Jay,
I have tried that, but with no success.  Perhaps the imported contacts were in the wrong format?
Brian
