I use TB Portable o my L-Drive. eM doens’t find it and so i can’t import my account. Need help please! I really want to try this software and buy it. But i can’t even test it in advance…
Hello Peter, unfortunately eM client is unable to detect Thunderbird files (profiles) on a non-default destination. Please make sure to copy your profiles data into the default thunderbird location and try the import feature again.
Hope this helps,
Thanks for your support, Paul!
I installed the normal version of TB and copied my profile from the portable version in the “AppData/Roaming”-folder after I got a hint via email by one of your account-managers.
It’s importing now, but kind of slow. But it’s ok - more than 180k emails to import
So - here we go! I hope your software is as good as it should be THX!
Pete.
Glad it works, please make sure to let us know if you come across any other issues or questions about the program, we’ll be happy to help.
