For some reason I cannot download messages anymore with IMAP. I have a third party e-mail provider who uses IMAP in address mail.provider.com. My username should be user@company.com when I login to that provider.
But it seems that eM client is always trying to send the credentials in format user@mail.provider.com.
There are several different domains in that e-mail provider so I think it should send my company domain also in login.
Logging in to that e-mail account providers webmail works fine with my credentials.
Hello Heikki,
have you tried manually changing the credentials in Tools>Accounts window in the IMAP tab? Try adding the correct domain to the user name.
Yes, I have “Use these settings” checked and it has my full e-mail address in the Username field.
I used Diagnotics tab to find the problem and it did go through all the possible authentication methods and reported that the problem was fixed.
But its still not receiving any e-mails.
When I open the Diagnostics tab again second time, it reports that server is not responding. If I press Fix, it will then again find the correct server settings and report “Settings have been fixed”. They just don’t seem to be saved.
