I use Google products almost exclusively which is why eM Client is so great for me.
However for all of the brilliant auto syncing it does with my contacts, calendar and task lists (which pretty much no other programme does without add-ons), I am finding the actual email part of it a let down - 2 main issues:
The IMAP connection regularly shows up with a connection error (which is surprising as I have a gmail account and it works on imap with every other programme I have used without fail.I have to run a diagnostics check almost every hour. It temporarily fixes it then the problem arises again.
I have 2 other email addresses imported into gmail and in the imap list they show up as separate folders just like on webmail. However, if I have received an email to one of these addreses and delete it from the main inbox, it is still in the folder of the particular email address. Is this a gmail issue?
Regards
Dave
