IMAP problem after upgrade to eM Client 7
3 month ago I posted, my problem with a SSL encrypted IMAP server.
https://forum.emclient.com/emclient/topics/imap-problem-after-upgrade-to-em-client-7
I don’t know why this was marked as solved, because the problem still remains.
here again my old text:
I just updated my eM Client from version 6 to 7.
eM Client 7 imported all the mails, calendars and contacts from eM Client 6.
But then the fetching of the e-mails from my mail server failed with the message “Der Server antwortet nicht” (Server not responding).
I’m using a cyrus mail server, with a self certified SSL certificate on the port 993.
It is configured as “Sicherheitsrichtlinie: SSL/TLS auf bestimmtem Port verwenden (Legacy)” (Security policy: Use SSL/TLS on special port (legacy)).
The SMTP server is working and it is using the same certificate.
I deleted all user data and reconfigured the e-mail stuff from the scratch but still the same issue.
I tried to enable the logs, but they all stay empty.
The only content I could find was in the log file without suffix:
19:39:19.301|00F|   System.Net Information: 0 : [6224] InitializeSecurityContext(credential = System.Net.SafeFreeCredential_SECURITY, context = 534d70:8b624f0, targetName = XXXXX.XX, inFlags = ReplayDetect, SequenceDetect, Confidentiality, AllocateMemory, InitManualCredValidation)
19:39:19.302|00F|   System.Net Information: 0 : [6224] InitializeSecurityContext(Anzahl von In-Buffers = 2, Länge von Out-Buffer = 0, zurückgegebener Code = InvalidToken).
How can I solve this problem?
EDIT:
The server is working correctly, I checked it with my mobile phone, tablet and also with a downgrade to eM Client 6.
Hello Torsten,
seems like the issue with marking your original post was an error in the forum system, since no one reacted to the original post otherwise.
As for the issue - if you have any security software (antivirus/firewall) make sure eM Client 7  isn’t blocked by it (if you made exceptions for v6, you might need to make them separately for v7).
If disabling the software/adding an exception does not solve the issue, please copy the full log after the error pops up.
Also make sure you are using the latest version of eM CLient 7 available: http://www.emclient.com/dist/v7.0.27804/setup.msi
Hello Olivia,
I don’t use any security software, no firewall and no virus detection software.
The Windows Firewall is turned off.
I enabled logging for database, network, SMTP and IMAP.
The files “2016-10-18_21-01-12  Auth.log”, “2016-10-18_21-01-12 t_…de IMAP.log”_ and “2016-10-18_21-01-12 t…de SMTP.log” are empty after I clicked on diagnose:
As you see, I get the “Server is not responding” message, before a connection was established.
For SMTP its working (same server). For SMTP its also asking to check the certificate.
Here the log file “2016-10-18_21-01-10.log”:
21:01:10.907|001| eM Client: 7.0.27804.0, .NET: 4.0.30319.42000, OS: Microsoft Windows NT 6.1.7601 Service Pack 1
21:01:11.687|001| 18.10.2016 21:01:11 Entered DbFolderRepository.Add transaction
21:01:11.687|001| 18.10.2016 21:01:11 Commited DbFolderRepository.Add transaction, added 1 items
21:01:11.687|001| 18.10.2016 21:01:11 Entered DbFolderRepository.Remove transaction
21:01:11.687|001| 18.10.2016 21:01:11 Commited DbFolderRepository.Remove transaction, removed 1 items
21:01:11.734|001| 18.10.2016 21:01:11 Entered DbFolderRepository.Add transaction
21:01:11.734|001| 18.10.2016 21:01:11 Commited DbFolderRepository.Add transaction, added 1 items
21:01:11.734|001| 18.10.2016 21:01:11 Entered DbFolderRepository.Remove transaction
21:01:11.734|001| 18.10.2016 21:01:11 Commited DbFolderRepository.Remove transaction, removed 1 items
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] TcpClient#15510466::TcpClient(track-point.selfhost.eu)
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] TcpClient#15510466::Connect(track-point.selfhost.eu)
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] DNS::GetHostAddresses(track-point.selfhost.eu)
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] DNS::GetHostByName(track-point.selfhost.eu)
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting DNS::GetHostByName() -\> IPHostEntry#6614365
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting DNS::GetHostAddresses() -\> IPAddress[]#823098
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] Socket#50208988::Socket(AddressFamily#2)
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting Socket#50208988::Socket()
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] Socket#42849418::Socket(AddressFamily#23)
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting Socket#42849418::Socket()
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] Socket#50208988::Connect(84.157.221.232#-388129452)
21:01:12.062|00E| System.Net.Sockets Verbose: 0 : [7832] Socket#50208988::Connect(84.157.221.232:993#-388129099)
21:01:12.124|00E| System.Net.Sockets Information: 0 : [7832] Socket#50208988 - Created connection from 172.29.1.117:62316 to 84.157.221.232:993.
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting Socket#50208988::Connect()
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] Socket#42849418::Close()
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] Socket#42849418::Dispose()
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting Socket#42849418::Close()
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting TcpClient#15510466::Connect()
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting TcpClient#15510466::TcpClient()
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] TcpClient#15510466::GetStream()
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting TcpClient#15510466::GetStream() -\> NetworkStream#63677697
21:01:12.124|00E| System.Net Information: 0 : [7832] SecureChannel#59134297::.ctor(hostname=track-point.selfhost.eu, #clientCertificates=0, encryptionPolicy=RequireEncryption)
21:01:12.124|00E| System.Net Information: 0 : [7832] Enumerating security packages:
21:01:12.124|00E| System.Net Information: 0 : [7832] Negotiate
21:01:12.124|00E| System.Net Information: 0 : [7832] NegoExtender
21:01:12.124|00E| System.Net Information: 0 : [7832] Kerberos
21:01:12.124|00E| System.Net Information: 0 : [7832] NTLM
21:01:12.124|00E| System.Net Information: 0 : [7832] Schannel
21:01:12.124|00E| System.Net Information: 0 : [7832] Microsoft Unified Security Protocol Provider
21:01:12.124|00E| System.Net Information: 0 : [7832] WDigest
21:01:12.124|00E| System.Net Information: 0 : [7832] TSSSP
21:01:12.124|00E| System.Net Information: 0 : [7832] pku2u
21:01:12.124|00E| System.Net Information: 0 : [7832] CREDSSP
21:01:12.124|00E| System.Net Information: 0 : [7832] SecureChannel#59134297 - Left with 0 client certificates to choose from.
21:01:12.124|00E| System.Net Information: 0 : [7832] AcquireCredentialsHandle(package = Microsoft Unified Security Protocol Provider, intent = Outbound, scc = System.Net.SecureCredential)
21:01:12.124|00E| System.Net Information: 0 : [7832] InitializeSecurityContext(credential = System.Net.SafeFreeCredential\_SECURITY, context = (null), targetName = track-point.selfhost.eu, inFlags = ReplayDetect, SequenceDetect, Confidentiality, AllocateMemory, InitManualCredValidation)
21:01:12.124|00E| System.Net Information: 0 : [7832] InitializeSecurityContext(In-Buffer length=0, Out-Buffer length=187, returned code=ContinueNeeded).
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] Socket#50208988::Send()
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] Data from Socket#50208988::Send
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 00000000 : 16 03 03 00 B6 01 00 00-B2 03 03 58 06 71 78 CA : ...........X.qx.
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 00000010 : 12 0D 35 09 BE AB 6E B0-79 AB 76 6C BF 8F FB 16 : ..5...n.y.vl....
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 00000020 : CC 55 50 7F A4 E9 CD BE-62 4E CE 00 00 38 C0 28 : .UP.....bN...8.(
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 00000030 : C0 27 C0 14 C0 13 00 9F-00 9E 00 39 00 33 00 9D : .'.........9.3..
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 00000040 : 00 9C 00 3D 00 3C 00 35-00 2F C0 2C C0 2B C0 24 : ...=.<.5.></.5.>21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 00000050 : C0 23 C0 0A C0 09 00 6A-00 40 00 38 00 32 00 0A : .#[email protected]..
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 00000060 : 00 13 00 05 00 04 01 00-00 51 00 00 00 1C 00 1A : .........Q......
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 00000070 : 00 00 17 74 72 61 63 6B-2D 70 6F 69 6E 74 2E 73 : ...track-point.s
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 00000080 : 65 6C 66 68 6F 73 74 2E-65 75 00 0A 00 06 00 04 : elfhost.eu......
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 00000090 : 00 17 00 18 00 0B 00 02-01 00 00 0D 00 14 00 12 : ................
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 000000A0 : 06 01 06 03 04 01 05 01-02 01 04 03 05 03 02 03 : ................
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] 000000B0 : 02 02 00 17 00 00 FF 01-00 01 00 : ...........
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting Socket#50208988::Send() -\> Int32#187
21:01:12.124|00E| System.Net.Sockets Verbose: 0 : [7832] Socket#50208988::Receive()
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] Data from Socket#50208988::Receive
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000000 : 16 03 03 00 59 : ....Y
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting Socket#50208988::Receive() -\> Int32#5
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] Socket#50208988::Receive()
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000005 : 02 00 00 55 03 03 1B 06-87 68 2F BB 7D 88 9D F8 : ...U.....h/.}...
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000015 : B5 1C 5C C6 52 00 17 D1-B1 77 A8 BF 94 FE 21 76 : ..\.R....w....!v
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000025 : 0D 60 9C A8 16 48 20 02-B2 EA 69 73 39 40 5B AF : .`...H ...is9@[.
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000035 : E8 C9 D4 25 76 A6 5B 6D-2F 3C B1 61 34 E2 35 0B : ...%v.[m/<.a4.5.></.a4.5.>21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000045 : D0 33 8B 86 3E CC 22 C0-14 00 00 0D FF 01 00 01 : .3..\>.".........
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000055 : 00 00 0B 00 04 03 00 01-02 : .........
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting Socket#50208988::Receive() -\> Int32#89
21:01:12.234|00E| System.Net Information: 0 : [7832] InitializeSecurityContext(credential = System.Net.SafeFreeCredential\_SECURITY, context = 46a648:890e478, targetName = track-point.selfhost.eu, inFlags = ReplayDetect, SequenceDetect, Confidentiality, AllocateMemory, InitManualCredValidation)
21:01:12.234|00E| System.Net Information: 0 : [7832] InitializeSecurityContext(In-Buffers count=2, Out-Buffer length=0, returned code=ContinueNeeded).
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000000 : 16 03 03 06 14 : .....
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] (printing 1024 out of 1556)
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000005 : 0B 00 06 10 00 06 0D 00-02 6A 30 82 02 66 30 82 : .........j0..f0.
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000015 : 01 CF 02 01 01 30 0D 06-09 2A 86 48 86 F7 0D 01 : .....0...\*.H....
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000025 : 01 04 05 00 30 81 90 31-0E 30 0C 06 03 55 04 0A : ....0..1.0...U..
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000035 : 13 05 54 72 61 63 6B 31-22 30 20 06 09 2A 86 48 : ..Track1"0 ..\*.H
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000045 : 86 F7 0D 01 09 01 16 13-69 6E 66 6F 40 74 72 61 : ........info@tra
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000055 : 63 6B 2D 70 6F 69 6E 74-2E 64 65 31 14 30 12 06 : ck-point.de1.0..
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000065 : 03 55 04 07 13 0B 53 61-63 68 73 65 6E 68 65 69 : .U....Sachsenhei
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000075 : 6D 31 1B 30 19 06 03 55-04 08 14 12 42 61 64 65 : m1.0...U....Bade
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000085 : 6E 2D 57 C3 BC 72 74 74-65 6D 62 65 72 67 31 0B : n-W..rttemberg1.
21:01:12.234|00E| System.Net.Sockets Verbose: 0 : [7832] 00000095 : 30 09 06 03 55 04 06 13-02 44 45 31 1A 30 18 06 : 0...U....DE1.0..
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000000A5 : 03 55 04 03 13 11 64 65-62 69 61 6E 2E 74 72 61 : .U....debian.tra
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000000B5 : 63 6B 2E 68 6F 6D 65 30-1E 17 0D 31 32 31 32 30 : ck.home0...12120
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000000C5 : 39 31 33 31 38 34 34 5A-17 0D 32 32 31 32 30 37 : 9131844Z..221207
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000000D5 : 31 33 31 38 34 34 5A 30-66 31 0B 30 09 06 03 55 : 131844Z0f1.0...U
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000000E5 : 04 06 13 02 44 45 31 1B-30 19 06 03 55 04 08 14 : ....DE1.0...U...
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000000F5 : 12 42 61 64 65 6E 2D 57-C3 BC 72 74 74 65 6D 62 : .Baden-W..rttemb
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000105 : 65 72 67 31 0E 30 0C 06-03 55 04 0A 13 05 54 72 : erg1.0...U....Tr
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000115 : 61 63 6B 31 15 30 13 06-03 55 04 0B 13 0C 53 65 : ack1.0...U....Se
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000125 : 63 75 72 65 20 49 4D 41-50 53 31 13 30 11 06 03 : cure IMAPS1.0...
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000135 : 55 04 03 13 0A 74 72 61-63 6B 2E 68 6F 6D 65 30 : U....track.home0
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000145 : 81 9F 30 0D 06 09 2A 86-48 86 F7 0D 01 01 01 05 : ..0...\*.H.......
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000155 : 00 03 81 8D 00 30 81 89-02 81 81 00 D5 8E 02 15 : .....0..........
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000165 : 0C F6 C8 19 4A 6A 90 39-42 35 BD 70 41 D4 9C B4 : ....Jj.9B5.pA...
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000175 : BA F4 60 65 CF E3 26 FA-AA 3C 70 48 4F 84 4A 76 : ..`e..&..<pho.jv></pho.jv>21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000185 : A4 20 B1 AA 00 69 96 92-EF 29 B4 2C 79 07 89 80 : . ...i...).,y...
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000195 : B9 98 CB 7C EF BC 28 85-E0 D7 60 0C 91 20 0C 65 : ...|..(...`.. .e
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000001A5 : F0 81 CF 92 18 4A 75 80-07 55 39 99 32 F2 77 07 : .....Ju..U9.2.w.
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000001B5 : 19 68 7D 1A 24 8F 8C 9D-00 C4 07 84 16 20 84 D4 : .h}.$........ ..
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000001C5 : 64 F1 A6 EA 18 48 56 9D-A2 48 E2 18 5E C7 9A 1E : d....HV..H..^...
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000001D5 : AE 00 B3 60 8A 37 F9 E4-61 21 61 11 02 03 01 00 : ...`.7..a!a.....
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000001E5 : 01 30 0D 06 09 2A 86 48-86 F7 0D 01 01 04 05 00 : .0...\*.H........
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000001F5 : 03 81 81 00 7D AE D4 18-4B 67 B2 47 89 03 45 1C : ....}...Kg.G..E.
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000205 : DA 87 48 BF 02 1C 0F 4F-BF DD 07 B6 3C 74 DF E1 : ..H....O....<t..></t..>21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000215 : EB F0 25 AC 8A F6 3D A5-CE C8 10 3E 2F 17 DE 82 : ..%...=....\>/...
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000225 : C9 0D C1 35 C3 CD F4 25-C2 45 5A 6E 63 E3 BD AD : ...5...%.EZnc...
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000235 : 34 36 48 02 52 CA 78 A9-0B CE 9C F6 F3 28 1F 77 : 46H.R.x......(.w
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000245 : 3B 3F 1D 1A 09 53 CC 96-94 6C F9 50 B7 AC 7B 67 : ;?...S...l.P..{g
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000255 : 22 7E 57 16 C2 D2 30 D8-11 FA C8 8F 67 86 AF 70 : "~W...0.....g..p
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000265 : CC 75 94 33 BD 6B DA 93-21 A5 04 74 F9 93 CF 84 : .u.3.k..!..t....
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000275 : 51 9C 2E D8 00 03 9D 30-82 03 99 30 82 03 02 A0 : Q......0...0....
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000285 : 03 02 01 02 02 09 00 E5-C1 CE A6 E1 D1 A2 47 30 : ..............G0
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000295 : 0D 06 09 2A 86 48 86 F7-0D 01 01 04 05 00 30 81 : ...\*.H........0.
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000002A5 : 90 31 0E 30 0C 06 03 55-04 0A 13 05 54 72 61 63 : .1.0...U....Trac
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000002B5 : 6B 31 22 30 20 06 09 2A-86 48 86 F7 0D 01 09 01 : k1"0 ..\*.H......
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000002C5 : 16 13 69 6E 66 6F 40 74-72 61 63 6B 2D 70 6F 69 : ..info@track-poi
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000002D5 : 6E 74 2E 64 65 31 14 30-12 06 03 55 04 07 13 0B : nt.de1.0...U....
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000002E5 : 53 61 63 68 73 65 6E 68-65 69 6D 31 1B 30 19 06 : Sachsenheim1.0..
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 000002F5 : 03 55 04 08 14 12 42 61-64 65 6E 2D 57 C3 BC 72 : .U....Baden-W..r
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000305 : 74 74 65 6D 62 65 72 67-31 0B 30 09 06 03 55 04 : ttemberg1.0...U.
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000315 : 06 13 02 44 45 31 1A 30-18 06 03 55 04 03 13 11 : ...DE1.0...U....
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000325 : 64 65 62 69 61 6E 2E 74-72 61 63 6B 2E 68 6F 6D : debian.track.hom
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000335 : 65 30 1E 17 0D 31 32 31-32 30 39 31 32 31 31 33 : e0...12120912113
21:01:12.249|00E| System.Net.Sockets Verbose: 0 : [7832] 00000345 : 31 5A 17 0D 32 32 31 32-30 37 31 32 31 31 33 31 : 1Z..221207121131
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] 00000355 : 5A 30 81 90 31 0E 30 0C-06 03 55 04 0A 13 05 54 : Z0..1.0...U....T
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] 00000365 : 72 61 63 6B 31 22 30 20-06 09 2A 86 48 86 F7 0D : rack1"0 ..\*.H...
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] 00000375 : 01 09 01 16 13 69 6E 66-6F 40 74 72 61 63 6B 2D : .....info@track-
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] 00000385 : 70 6F 69 6E 74 2E 64 65-31 14 30 12 06 03 55 04 : point.de1.0...U.
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] 00000395 : 07 13 0B 53 61 63 68 73-65 6E 68 65 69 6D 31 1B : ...Sachsenheim1.
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] 000003A5 : 30 19 06 03 55 04 08 14-12 42 61 64 65 6E 2D 57 : 0...U....Baden-W
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] 000003B5 : C3 BC 72 74 74 65 6D 62-65 72 67 31 0B 30 09 06 : ..rttemberg1.0..
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] 000003C5 : 03 55 04 06 13 02 44 45-31 1A 30 18 06 03 55 04 : .U....DE1.0...U.
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] 000003D5 : 03 13 11 64 65 62 69 61-6E 2E 74 72 61 63 6B 2E : ...debian.track.
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] 000003E5 : 68 6F 6D 65 30 81 9F 30-0D 06 09 2A 86 48 86 F7 : home0..0...\*.H..
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] 000003F5 : 0D 01 01 01 05 00 03 81-8D 00 30 81 89 02 81 81 : ..........0.....
21:01:12.265|00E| System.Net.Sockets Verbose: 0 : [7832] Exiting Socket#50208988::Receive() -\> Int32#1556
21:01:12.265|00E| System.Net Information: 0 : [7832] InitializeSecurityContext(credential = System.Net.SafeFreeCredential\_SECURITY, context = 46a648:890e478, targetName = track-point.selfhost.eu, inFlags = ReplayDetect, SequenceDetect, Confidentiality, AllocateMemory, InitManualCredValidation)
21:01:12.265|00E| System.Net Information: 0 : [7832] InitializeSecurityContext(In-Buffers count=2, Out-Buffer length=0, returned code=InvalidToken).
21:01:18.380|002| System.Net.Sockets Verbose: 0 : [3756] TcpClient#15510466::Dispose()
21:01:18.380|002| System.Net.Sockets Verbose: 0 : [3756] Exiting TcpClient#15510466::Dispose()
21:01:20.970|00C| System.Net.Sockets Verbose: 0 : [3020] TcpClient#36610825::TcpClient(track-point.selfhost.eu)
21:01:20.970|00C| System.Net.Sockets Verbose: 0 : [3020] TcpClient#36610825::Connect(track-point.selfhost.eu)
21:01:20.970|00C| System.Net.Sockets Verbose: 0 : [3020] DNS::GetHostAddresses(track-point.selfhost.eu)
21:01:20.970|00C| System.Net.Sockets Verbose: 0 : [3020] DNS::GetHostByName(track-point.selfhost.eu)
21:01:20.970|004| System.Net.Sockets Verbose: 0 : [6044] TcpClient#61462644::TcpClient(track-point.selfhost.eu)
21:01:20.970|004| System.Net.Sockets Verbose: 0 : [6044] TcpClient#61462644::Connect(track-point.selfhost.eu)
21:01:20.970|004| System.Net.Sockets Verbose: 0 : [6044] DNS::GetHostAddresses(track-point.selfhost.eu)
21:01:20.970|004| System.Net.Sockets Verbose: 0 : [6044] DNS::GetHostByName(track-point.selfhost.eu)
21:01:21.016|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting DNS::GetHostByName() -\> IPHostEntry#61325552
21:01:21.016|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting DNS::GetHostAddresses() -\> IPAddress[]#29028787
21:01:21.016|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#62130720::Socket(AddressFamily#2)
21:01:21.016|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Socket()
21:01:21.016|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#4593845::Socket(AddressFamily#23)
21:01:21.016|004| System.Net.Sockets Verbose: 0 : [6044] Exiting DNS::GetHostByName() -\> IPHostEntry#15647122
21:01:21.016|004| System.Net.Sockets Verbose: 0 : [6044] Exiting DNS::GetHostAddresses() -\> IPAddress[]#60154108
21:01:21.016|004| System.Net.Sockets Verbose: 0 : [6044] Socket#55276729::Socket(AddressFamily#2)
21:01:21.016|004| System.Net.Sockets Verbose: 0 : [6044] Exiting Socket#55276729::Socket()
21:01:21.016|004| System.Net.Sockets Verbose: 0 : [6044] Socket#19960630::Socket(AddressFamily#23)
21:01:21.016|004| System.Net.Sockets Verbose: 0 : [6044] Exiting Socket#19960630::Socket()
21:01:21.016|004| System.Net.Sockets Verbose: 0 : [6044] Socket#55276729::Connect(84.157.221.232#-388129452)
21:01:21.016|004| System.Net.Sockets Verbose: 0 : [6044] Socket#55276729::Connect(84.157.221.232:993#-388129099)
21:01:21.016|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#4593845::Socket()
21:01:21.016|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#62130720::Connect(84.157.221.232#-388129452)
21:01:21.016|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#62130720::Connect(84.157.221.232:465#-388129659)
21:01:21.048|004| System.Net.Sockets Information: 0 : [6044] Socket#55276729 - Created connection from 172.29.1.117:62317 to 84.157.221.232:993.
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] Exiting Socket#55276729::Connect()
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] Socket#19960630::Close()
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] Socket#19960630::Dispose()
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] Exiting Socket#19960630::Close()
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] Exiting TcpClient#61462644::Connect()
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] Exiting TcpClient#61462644::TcpClient()
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] TcpClient#61462644::GetStream()
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] Exiting TcpClient#61462644::GetStream() -\> NetworkStream#16520064
21:01:21.048|004| System.Net Information: 0 : [6044] SecureChannel#11377025::.ctor(hostname=track-point.selfhost.eu, #clientCertificates=0, encryptionPolicy=RequireEncryption)
21:01:21.048|004| System.Net Information: 0 : [6044] SecureChannel#11377025 - Left with 0 client certificates to choose from.
21:01:21.048|004| System.Net Information: 0 : [6044] Using the cached credential handle.
21:01:21.048|004| System.Net Information: 0 : [6044] InitializeSecurityContext(credential = System.Net.SafeFreeCredential\_SECURITY, context = (null), targetName = track-point.selfhost.eu, inFlags = ReplayDetect, SequenceDetect, Confidentiality, AllocateMemory, InitManualCredValidation)
21:01:21.048|004| System.Net Information: 0 : [6044] InitializeSecurityContext(In-Buffer length=0, Out-Buffer length=187, returned code=ContinueNeeded).
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] Socket#55276729::Send()
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] Data from Socket#55276729::Send
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 00000000 : 16 03 03 00 B6 01 00 00-B2 03 03 58 06 71 81 D4 : ...........X.q..
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 00000010 : B1 6F 87 37 E5 96 E4 AA-20 BD 9D F6 87 60 DA AF : .o.7.... ....`..
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 00000020 : 78 A3 DA 4F E5 75 12 97-FA 8D F5 00 00 38 C0 28 : x..O.u.......8.(
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 00000030 : C0 27 C0 14 C0 13 00 9F-00 9E 00 39 00 33 00 9D : .'.........9.3..
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 00000040 : 00 9C 00 3D 00 3C 00 35-00 2F C0 2C C0 2B C0 24 : ...=.<.5.></.5.>21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 00000050 : C0 23 C0 0A C0 09 00 6A-00 40 00 38 00 32 00 0A : .#[email protected]..
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 00000060 : 00 13 00 05 00 04 01 00-00 51 00 00 00 1C 00 1A : .........Q......
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 00000070 : 00 00 17 74 72 61 63 6B-2D 70 6F 69 6E 74 2E 73 : ...track-point.s
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 00000080 : 65 6C 66 68 6F 73 74 2E-65 75 00 0A 00 06 00 04 : elfhost.eu......
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 00000090 : 00 17 00 18 00 0B 00 02-01 00 00 0D 00 14 00 12 : ................
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 000000A0 : 06 01 06 03 04 01 05 01-02 01 04 03 05 03 02 03 : ................
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] 000000B0 : 02 02 00 17 00 00 FF 01-00 01 00 : ...........
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] Exiting Socket#55276729::Send() -\> Int32#187
21:01:21.048|004| System.Net.Sockets Verbose: 0 : [6044] Socket#55276729::Receive()
21:01:21.063|00C| System.Net.Sockets Information: 0 : [3020] Socket#62130720 - Created connection from 172.29.1.117:62318 to 84.157.221.232:465.
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Connect()
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#4593845::Close()
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#4593845::Dispose()
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#4593845::Close()
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting TcpClient#36610825::Connect()
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting TcpClient#36610825::TcpClient()
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] TcpClient#36610825::GetStream()
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting TcpClient#36610825::GetStream() -\> NetworkStream#42147222
21:01:21.063|00C| System.Net Information: 0 : [3020] SecureChannel#19210254::.ctor(hostname=track-point.selfhost.eu, #clientCertificates=0, encryptionPolicy=RequireEncryption)
21:01:21.063|00C| System.Net Information: 0 : [3020] SecureChannel#19210254 - Left with 0 client certificates to choose from.
21:01:21.063|00C| System.Net Information: 0 : [3020] Using the cached credential handle.
21:01:21.063|00C| System.Net Information: 0 : [3020] InitializeSecurityContext(credential = System.Net.SafeFreeCredential\_SECURITY, context = (null), targetName = track-point.selfhost.eu, inFlags = ReplayDetect, SequenceDetect, Confidentiality, AllocateMemory, InitManualCredValidation)
21:01:21.063|00C| System.Net Information: 0 : [3020] InitializeSecurityContext(In-Buffer length=0, Out-Buffer length=187, returned code=ContinueNeeded).
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#62130720::Send()
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] Data from Socket#62130720::Send
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 00000000 : 16 03 03 00 B6 01 00 00-B2 03 03 58 06 71 81 B6 : ...........X.q..
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 00000010 : 34 47 B1 43 DF 4A B1 CC-44 E3 01 46 D4 7C CA 9F : 4G.C.J..D..F.|..
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 00000020 : 62 DA F1 AE E4 92 0A 06-3F 51 7F 00 00 38 C0 28 : b.......?Q...8.(
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 00000030 : C0 27 C0 14 C0 13 00 9F-00 9E 00 39 00 33 00 9D : .'.........9.3..
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 00000040 : 00 9C 00 3D 00 3C 00 35-00 2F C0 2C C0 2B C0 24 : ...=.<.5.></.5.>21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 00000050 : C0 23 C0 0A C0 09 00 6A-00 40 00 38 00 32 00 0A : .#[email protected]..
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 00000060 : 00 13 00 05 00 04 01 00-00 51 00 00 00 1C 00 1A : .........Q......
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 00000070 : 00 00 17 74 72 61 63 6B-2D 70 6F 69 6E 74 2E 73 : ...track-point.s
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 00000080 : 65 6C 66 68 6F 73 74 2E-65 75 00 0A 00 06 00 04 : elfhost.eu......
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 00000090 : 00 17 00 18 00 0B 00 02-01 00 00 0D 00 14 00 12 : ................
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 000000A0 : 06 01 06 03 04 01 05 01-02 01 04 03 05 03 02 03 : ................
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] 000000B0 : 02 02 00 17 00 00 FF 01-00 01 00 : ...........
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Send() -\> Int32#187
21:01:21.063|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#62130720::Receive()
21:01:21.094|00C| System.Net.Sockets Verbose: 0 : [3020] Data from Socket#62130720::Receive
21:01:21.094|00C| System.Net.Sockets Verbose: 0 : [3020] 00000000 : 16 03 03 00 5D : ....]
21:01:21.094|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Receive() -\> Int32#5
21:01:21.094|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#62130720::Receive()
21:01:21.094|00C| System.Net.Sockets Verbose: 0 : [3020] 00000005 : 02 00 00 59 03 03 38 33-E0 12 4D 01 CC 86 81 6C : ...Y..83..M....l
21:01:21.094|00C| System.Net.Sockets Verbose: 0 : [3020] 00000015 : 0F C4 54 7D 02 5C 4D F5-22 B3 C5 D4 81 95 D9 99 : ..T}.\M.".......
21:01:21.094|00C| System.Net.Sockets Verbose: 0 : [3020] 00000025 : 40 80 4F 52 75 96 20 34-2B 41 4A 4F 39 2A 8B 8E : @.ORu. 4+AJO9\*..
21:01:21.094|00C| System.Net.Sockets Verbose: 0 : [3020] 00000035 : CE 6D A6 54 6F CD 5B C7-65 8F 8A B8 8D 5C 60 DE : .m.To.[.e....\`.
21:01:21.094|00C| System.Net.Sockets Verbose: 0 : [3020] 00000045 : 47 2E F5 FA 9F 04 98 C0-28 00 00 11 00 00 00 00 : G.......(.......
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000055 : FF 01 00 01 00 00 0B 00-04 03 00 01 02 : .............
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Receive() -\> Int32#93
21:01:21.110|00C| System.Net Information: 0 : [3020] InitializeSecurityContext(credential = System.Net.SafeFreeCredential\_SECURITY, context = 46a648:8949f40, targetName = track-point.selfhost.eu, inFlags = ReplayDetect, SequenceDetect, Confidentiality, AllocateMemory, InitManualCredValidation)
21:01:21.110|00C| System.Net Information: 0 : [3020] InitializeSecurityContext(In-Buffers count=2, Out-Buffer length=0, returned code=ContinueNeeded).
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#62130720::Receive()
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] Data from Socket#62130720::Receive
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000000 : 16 03 03 03 45 : ....E
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Receive() -\> Int32#5
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000005 : 0B 00 03 41 00 03 3E 00-03 3B 30 82 03 37 30 82 : ...A..\>..;0..70.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000015 : 02 A0 A0 03 02 01 02 02-09 00 CA 75 83 3C 2B FB : ...........u.21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000025 : 82 1D 30 0D 06 09 2A 86-48 86 F7 0D 01 01 05 05 : ..0...\*.H.......
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000035 : 00 30 71 31 0B 30 09 06-03 55 04 06 13 02 44 45 : .0q1.0...U....DE
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000045 : 31 1B 30 19 06 03 55 04-08 13 12 42 61 64 65 6E : 1.0...U....Baden
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000055 : 2D 57 75 65 72 74 74 65-6D 62 65 72 67 31 14 30 : -Wuerttemberg1.0
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000065 : 12 06 03 55 04 07 13 0B-53 61 63 68 73 65 6E 68 : ...U....Sachsenh
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000075 : 65 69 6D 31 0E 30 0C 06-03 55 04 0A 13 05 54 72 : eim1.0...U....Tr
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000085 : 61 63 6B 31 1F 30 1D 06-03 55 04 03 13 16 74 72 : ack1.0...U....tr
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000095 : 61 63 6B 2D 70 6F 69 6E-74 2E 64 79 6E 64 6E 73 : ack-point.dyndns
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000000A5 : 2E 6F 72 67 30 1E 17 0D-31 31 31 32 30 33 31 38 : .org0...11120318
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000000B5 : 32 38 31 36 5A 17 0D 32-31 31 31 33 30 31 38 32 : 2816Z..211130182
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000000C5 : 38 31 36 5A 30 71 31 0B-30 09 06 03 55 04 06 13 : 816Z0q1.0...U...
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000000D5 : 02 44 45 31 1B 30 19 06-03 55 04 08 13 12 42 61 : .DE1.0...U....Ba
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000000E5 : 64 65 6E 2D 57 75 65 72-74 74 65 6D 62 65 72 67 : den-Wuerttemberg
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000000F5 : 31 14 30 12 06 03 55 04-07 13 0B 53 61 63 68 73 : 1.0...U....Sachs
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000105 : 65 6E 68 65 69 6D 31 0E-30 0C 06 03 55 04 0A 13 : enheim1.0...U...
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000115 : 05 54 72 61 63 6B 31 1F-30 1D 06 03 55 04 03 13 : .Track1.0...U...
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000125 : 16 74 72 61 63 6B 2D 70-6F 69 6E 74 2E 64 79 6E : .track-point.dyn
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000135 : 64 6E 73 2E 6F 72 67 30-81 9F 30 0D 06 09 2A 86 : dns.org0..0...\*.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000145 : 48 86 F7 0D 01 01 01 05-00 03 81 8D 00 30 81 89 : H............0..
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000155 : 02 81 81 00 C4 73 53 C2-CC B9 04 E4 A6 8A 16 E4 : .....sS.........
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000165 : 22 AB 5B C2 B9 D1 16 32-41 1C B7 2E 57 54 E6 62 : ".[....2A...WT.b
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000175 : 6D 7E D1 CB 48 DB C5 38-3E 9F 30 46 B8 9F E7 94 : m~..H..8\>.0F....
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000185 : 9E 43 C1 55 36 59 7C 84-85 DE 40 F1 D8 FE EE 1F : .C.U6Y|...@.....
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000195 : C1 3D 24 FD B1 D4 5F 40-8A F6 A7 A3 46 B7 F2 D9 : .=$...\[email protected]...
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000001A5 : 8D C7 C5 9B FE 73 5C 99-84 E0 A4 F5 B0 19 9D 0D : .....s\.........
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000001B5 : 46 CC C5 5F 0B BF 44 7A-82 1A 89 7F 41 3B 6F D0 : F..\_..Dz....A;o.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000001C5 : 0A CE B3 B5 43 2E 1E C5-FB 23 9F 66 0A A1 C0 D0 : ....C....#.f....
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000001D5 : 73 A6 6B 07 02 03 01 00-01 A3 81 D6 30 81 D3 30 : s.k.........0..0
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000001E5 : 1D 06 03 55 1D 0E 04 16-04 14 32 90 A6 91 49 95 : ...U......2...I.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000001F5 : 27 EA 69 87 F5 49 78 C8-35 63 EF 03 55 40 30 81 : '.i..Ix.5c..U@0.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000205 : A3 06 03 55 1D 23 04 81-9B 30 81 98 80 14 32 90 : ...U.#...0....2.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000215 : A6 91 49 95 27 EA 69 87-F5 49 78 C8 35 63 EF 03 : ..I.'.i..Ix.5c..
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000225 : 55 40 A1 75 A4 73 30 71-31 0B 30 09 06 03 55 04 : [email protected].
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000235 : 06 13 02 44 45 31 1B 30-19 06 03 55 04 08 13 12 : ...DE1.0...U....
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000245 : 42 61 64 65 6E 2D 57 75-65 72 74 74 65 6D 62 65 : Baden-Wuerttembe
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000255 : 72 67 31 14 30 12 06 03-55 04 07 13 0B 53 61 63 : rg1.0...U....Sac
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000265 : 68 73 65 6E 68 65 69 6D-31 0E 30 0C 06 03 55 04 : hsenheim1.0...U.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000275 : 0A 13 05 54 72 61 63 6B-31 1F 30 1D 06 03 55 04 : ...Track1.0...U.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000285 : 03 13 16 74 72 61 63 6B-2D 70 6F 69 6E 74 2E 64 : ...track-point.d
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000295 : 79 6E 64 6E 73 2E 6F 72-67 82 09 00 CA 75 83 3C : yndns.org....u.\<
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000002A5 : 2B FB 82 1D 30 0C 06 03-55 1D 13 04 05 30 03 01 : +...0...U....0..
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000002B5 : 01 FF 30 0D 06 09 2A 86-48 86 F7 0D 01 01 05 05 : ..0...\*.H.......
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000002C5 : 00 03 81 81 00 54 57 87-33 0E A6 51 3C 37 CC CF : .....TW.3..Q\<7..
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000002D5 : 9A 70 EA 41 59 C2 38 35-68 04 88 80 79 AA 73 FA : .p.AY.85h...y.s.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000002E5 : 84 A9 34 1F 33 82 A7 75-88 DA 8E 72 52 A6 34 2B : ..4.3..u...rR.4+
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000002F5 : F9 69 1A 83 F6 77 AC 96-49 92 50 76 E6 30 CA 6C : .i...w..I.Pv.0.l
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000305 : 5B FF C8 86 10 ED EB D8-63 19 EE 5C 63 A5 A2 C0 : [.......c..\c...
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000315 : 60 F3 06 B3 47 4B B7 88-C7 52 63 FF 55 36 FE 4B : `...GK...Rc.U6.K
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000325 : E2 75 91 E7 3D 9A 43 F0-3C A1 00 9F A6 0A 82 5B : .u..=.C.<......></......>21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000335 : DC 1E E2 29 76 E5 F7 6F-B9 39 F1 55 EF 2D 23 77 : ...)v..o.9.U.-#w
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000345 : 38 76 11 E4 BB : 8v...
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Receive() -\> Int32#837
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000000 : 16 03 03 00 CD : .....
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000005 : 0C 00 00 C9 03 00 17 41-04 CD A6 F8 3E 59 A3 1F : .......A....\>Y..
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000015 : A2 AA 2E FA AB 1F 3F 9E-81 55 0D 68 33 6F 81 EE : ......?..U.h3o..
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000025 : 88 32 D5 AC 93 40 30 29-8C 94 0F 39 D9 72 87 B7 : .2...@0)...9.r..
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000035 : 66 30 3C B8 21 69 83 56-C4 BE C1 57 1C 5A AF 35 : f0<.></.>21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000045 : E8 F7 9A 34 C7 73 60 C9-48 06 01 00 80 A0 D8 F7 : ...4.s`.H.......
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000055 : 99 39 D4 CF 41 64 F6 0B-04 14 6B E5 AD 4E 40 CF : .9..Ad....k..N@.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000065 : D9 7E DC 29 74 53 15 5A-1B F0 17 FB 7D 1E 03 93 : .~.)tS.Z....}...
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000075 : 80 75 D0 3E 52 79 52 0A-8D 99 46 EA 32 0C 32 1D : .u.\>RyR...F.2.2.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000085 : F3 D5 B2 4C 88 C0 91 9A-99 A5 C5 0E E5 E0 42 AF : ...L..........B.
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 00000095 : 95 97 6A C9 9E 7E 56 CD-29 57 62 F8 C1 C7 B9 F2 : ..j..~V.)Wb.....
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000000A5 : AC 58 98 70 04 E8 43 C5-85 A8 9B 6C 60 55 58 33 : .X.p..C....l`UX3
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000000B5 : DB 78 F0 BC 3B 89 2E 43-8D F8 DD 55 B6 18 C5 98 : .x..;..C...U....
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] 000000C5 : 31 8D 20 B1 D2 05 79 49-9B 40 0E DA 9F : 1. ...yI.@...
21:01:21.110|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Receive() -\> Int32#205
21:01:21.126|00C| System.Net Information: 0 : [3020] InitializeSecurityContext(In-Buffers count=2, Out-Buffer length=0, returned code=ContinueNeeded).
21:01:21.126|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#62130720::Receive()
21:01:21.126|00C| System.Net.Sockets Verbose: 0 : [3020] Data from Socket#62130720::Receive
21:01:21.126|00C| System.Net.Sockets Verbose: 0 : [3020] 00000000 : 16 03 03 00 04 : .....
21:01:21.126|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Receive() -\> Int32#5
21:01:21.126|00C| System.Net.Sockets Verbose: 0 : [3020] 00000005 : 0E 00 00 00 : ....
21:01:21.126|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Receive() -\> Int32#4
21:01:21.126|00C| System.Net Information: 0 : [3020] InitializeSecurityContext(credential = System.Net.SafeFreeCredential\_SECURITY, context = 46a648:8949f40, targetName = track-point.selfhost.eu, inFlags = ReplayDetect, SequenceDetect, Confidentiality, AllocateMemory, InitManualCredValidation)
21:01:21.141|00C| System.Net Information: 0 : [3020] InitializeSecurityContext(In-Buffers count=2, Out-Buffer length=182, returned code=ContinueNeeded).
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#62130720::Send()
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] Data from Socket#62130720::Send
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 00000000 : 16 03 03 00 46 10 00 00-42 41 04 E8 E7 47 F2 CD : ....F...BA...G..
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 00000010 : 9F 16 D4 9B 17 F2 E2 60-9E F7 9E 3E 5C F5 29 47 : .......`...\>\.)G
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 00000020 : 30 FC 36 91 FD 42 BB 90-2E 9C 2E D3 B2 90 7F 4C : 0.6..B.........L
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 00000030 : 02 11 D4 80 D9 9B 18 49-33 EF 5F D8 38 2A 92 7F : .......I3.\_.8\*..
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 00000040 : BC 9F A6 1B 39 5C A6 26-72 F3 36 14 03 03 00 01 : ....9\.&r.6.....
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 00000050 : 01 16 03 03 00 60 78 7F-97 1B 4E D4 BC 87 5F 1A : .....`x...N...\_.
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 00000060 : DD AF 63 9A E5 0C 02 9B-38 D4 AB 13 AA 0A 37 42 : ..c.....8.....7B
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 00000070 : F5 7D FC 91 CA FD F9 2A-C4 71 CF 19 2D 9C 48 58 : .}.....\*.q..-.HX
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 00000080 : 4B 70 49 1C DD 1F BA DB-1A 86 22 74 00 13 B8 32 : KpI......."t...2
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 00000090 : 1F 89 63 3F C7 0A CC C5-7A 0F F7 99 33 16 C1 3D : ..c?....z...3..=
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 000000A0 : 9C AC A7 54 B0 5D 67 FE-D5 29 76 98 42 0B A9 99 : ...T.]g..)v.B...
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] 000000B0 : D7 5F 39 C3 27 7F : .\_9.'.
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Send() -\> Int32#182
21:01:21.141|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#62130720::Receive()
21:01:21.971|004| System.Net.Sockets Verbose: 0 : [6044] Data from Socket#55276729::Receive
21:01:21.971|00C| System.Net.Sockets Verbose: 0 : [3020] Data from Socket#62130720::Receive
21:01:21.971|00C| System.Net.Sockets Verbose: 0 : [3020] 00000000 : 14 03 03 00 01 : .....
21:01:21.971|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Receive() -\> Int32#5
21:01:21.971|00C| System.Net.Sockets Verbose: 0 : [3020] Socket#62130720::Receive()
21:01:21.971|00C| System.Net.Sockets Verbose: 0 : [3020] 00000005 : 01 : .
21:01:21.971|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Receive() -\> Int32#1
21:01:21.971|00C| System.Net Information: 0 : [3020] InitializeSecurityContext(credential = System.Net.SafeFreeCredential\_SECURITY, context = 46a648:8949f40, targetName = track-point.selfhost.eu, inFlags = ReplayDetect, SequenceDetect, Confidentiality, AllocateMemory, InitManualCredValidation)
21:01:21.971|00C| System.Net Information: 0 : [3020] InitializeSecurityContext(In-Buffers count=2, Out-Buffer length=0, returned code=ContinueNeeded).
21:01:21.971|00C| System.Net.Sockets Verbose: 0 : [3020] 00000000 : 16 03 03 00 60 : ....`
21:01:21.986|00C| System.Net.Sockets Verbose: 0 : [3020] Data from Socket#62130720::Receive
21:01:21.986|00C| System.Net.Sockets Verbose: 0 : [3020] 00000005 : 6A 27 F0 A7 D8 C8 1D D5-91 89 8E DD 06 67 A4 18 : j'...........g..
21:01:21.986|00C| System.Net.Sockets Verbose: 0 : [3020] 00000015 : 37 B0 27 4B 4C 0B BD 41-63 68 90 51 3C 0A 82 2B : 7.'KL..Ach.Q<..></..>21:01:21.986|00C| System.Net.Sockets Verbose: 0 : [3020] 00000025 : 05 6F D8 54 9C DE A9 47-E0 FD 68 E6 66 A1 56 E9 : .o.T...G..h.f.V.
21:01:21.986|00C| System.Net.Sockets Verbose: 0 : [3020] 00000035 : 83 FB 84 46 94 A9 83 64-C8 03 49 B1 68 04 5D 4E : ...F...d..I.h.]N
21:01:21.986|00C| System.Net.Sockets Verbose: 0 : [3020] 00000045 : 8B EE 0D 92 36 34 72 AD-47 32 B8 14 B7 D1 F6 2D : ....64r.G2.....-
21:01:21.986|00C| System.Net.Sockets Verbose: 0 : [3020] 00000055 : F2 64 BE 7C 01 42 27 91-2E 5B ED 17 5B 15 82 D4 : .d.|.B'..[..[...
21:01:21.986|00C| System.Net.Sockets Verbose: 0 : [3020] Exiting Socket#62130720::Receive() -\> Int32#96
21:01:21.986|00C| System.Net Information: 0 : [3020] InitializeSecurityContext(credential = System.Net.SafeFreeCredential\_SECURITY, context = 46a648:8949f40, targetName = track-point.selfhost.eu, inFlags = ReplayDetect, SequenceDetect, Confidentiality, AllocateMemory, InitManualCredValidation)
21:01:21.986|004| System.Net.Sockets Verbose: 0 : [6044] 00000000 : 16 03 03 00 59 : ....Y
21:01:21.986|004| System.Net.Sockets Verbose: 0 : [6044] Exiting Socket#55276729::Receive() -\> Int32#5
21:01:21.986|004| System.Net.Sockets Verbose: 0 : [6044] Socket#55276729::Receive()
21:01:21.986|004| System.Net&
Hello Torsten,
I need the log from the Tools>Operations>Log window.
The other logs (IMAP SMTP etc) only start logging after restarting eM Client.
But since the problem is with the connection, I don’t need those logs at this time.
Hello Olivia,
Here the Log from the Log window:
15:58:11 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
15:58:11 [email protected] [IMAP] MailClient.Accounts.ConnectionException: A call to SSPI failed, see inner exception. ---\> System.Security.Authentication.AuthenticationException: A call to SSPI failed, see inner exception. ---\> System.ComponentModel.Win32Exception: Das Token, das der Funktion übergeben wurde, ist ungültig
15:58:11 --- End of inner exception stack trace ---
15:58:11 at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, Exception exception)
15:58:11 at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)
15:58:11 at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)
15:58:11 at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)
15:58:11 at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)
15:58:11 at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)
15:58:11 at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest)
15:58:11 at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
15:58:11 at System.Net.Security.SslStream.AuthenticateAsClient(String targetHost, X509CertificateCollection clientCertificates, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation)
15:58:11 at MailClient.Imap.Base.Connection.\<\>c\_\_DisplayClass43\_0.<connect>b__0()<br>15:58:11
 at MailClient.Imap.Base.Connection.Connect(Func`1 getStream)<br>15:58:11
 at MailClient.Imap.Base.Connection.Connect(String receiveHost, Int32 receivePort, Boolean explicitSsl)<br>15:58:11
 at MailClient.Protocols.Imap.ConnectionPoolEntry.Reconnect(CancellationToken cancellationToken)<br>15:58:11
 --- End of inner exception stack trace ---<br>15:58:11
 at MailClient.Protocols.Imap.ConnectionPoolEntry.Connect(CancellationToken cancellationToken)<br>15:58:11
 at MailClient.Protocols.Imap.ConnectionPool.AcquireConnection(Folder mailFolder, Boolean idle, Boolean forStore)<br>15:58:11
 at MailClient.Protocols.Imap.ConnectionContext..ctor(ImapAccount account)<br>15:58:11
 at MailClient.Protocols.Imap.Synchronizer.SynchronizeFoldersCommand.ExecuteInternal(WorkerStatus status)<br>15:58:11
 at MailClient.Protocols.Imap.Synchronizer.ImapCommand.Execute(WorkerStatus status)<br>15:58:11
 at MailClient.Commands.Command.Process(WorkerStatus status)<br><br></connect>
Hello Torsten,
if this is your server, would it be possible to create a testing account for us so we can analyze the issue live/up close?
You can send the info to [email protected] with a link to this forum thread.
Hello Olivia,
it is already a month ago that I send you the access data.
And I didn’t receive any answer till now,
neither I could see any access to the test account i created for you.
Did you receive my email?
Do you need any further help?
How can i support you with solving this issue?
Thank You!
