Imap emails not being deleted
Hi, I am running eM client 6.0.19861.0
I am using the free version, and have it setup for IMAP for gmail (google mail). Regularly, when I delete emails from my junk folder, they go to the trash folder, and then even if I empty the trash folder, the emails are back in the junk folder again and there is no way to permanently delete them in eM client except to logon to my gmail via the web interface and delete them there. Any ideas? I know others have had issues with this, but there doesn’t seem to be a solution. It is definitely an issue somewhere either with the eM client itself, or with the connection that the eM client is making with the gmail servers, as I have no problems with this if I interface with gmail via a web interface (html).
Thanks for any help.
Justin
Hi, I will need your IMAP logs, go to tools - settings - advanced, check IMAP under your account, apply and restart eM Client.
Simulate steps that leads to your issue and after that send logs… to galis@emclient.com together with this topic’s URL in subject.
