I used Aid4Mail and converted the SeaMonkey emails from old laptop and tried - several times - to import them into eM on new laptop.
Nothing happens. I get a dialog that they’re importing but they are not showing up in the email folders (not in local, email account folders or smart folders) The conversion from the old SeaMonkey did turn the files into .sbd files.
I’ve been looking for a document on converting from SeaMonkey, or sdb files, can’t find anything.
I am not sure but Seamonkey uses same profiles for storing your data as Thunderbird so you should be able to copy your profile to Thunderbirds folder in AppData and then use “Import from Thunderbird” option in eM Client. Please let me know if you need any further information.
Thanks George, I’ll try this by copying over the entire profiles folders to the new laptop. I’ll let you know if it works or not.
